Center Point Sonar
am looking for the center point from a servo.am trying to use the sonar. is it left 0 degree top 90 degree and right 180 degree.
thanks anyone;)
Maybe I don't understand... but plug in your servo to your ezb4 and find out. Then centre it with ezb builder then attach your sonar the way to want it to be.... then you're done...
Patrick, if that is a picture of the servo you are asking about, you need a voltage regulator. It is a 6v servo. If you plug it directly into the EZ-B with a Lipo battery or a 6AAA battery pack you will burn it out.
hi alan
i have a voltregulator for the ping sensor.but i use servo's from here.
thanks
