Hi Nomad,
The Galapagosbot is in the same configuration as Six so their projects are similar. If you'd like to switch the servo around on your own for aesthetic reasons, no prob! Just change the example file so the servo is at 1 instead of 180 and physically flip the servo around.
jeremie
thanks i will.
when will the download galapagos be availeble in ARC?
found this
Hi Nomad,
The Galapagosbot Example Project should be available tonight or tomorrow. We are now making changes to the example to be in the configuration you like, we hope you'll enjoy it!
jeremie
wow thats cool.am hoping to have mine galapagos end nex month.
thank you
jeremie
will the six configuration also adjusted like the galapagos bot. or is there an easy fix for that.
Six's leg servos are in a clockwise pattern so it looks pretty symmetrical, it will stay the same in our example.
I would leave the configuration the way it is if I were you but if you really want to change them you can use the servo "fine tune" feature. You'd just have do a bit of simple math to invert the servo values that you'd want to change.
if i change the fine tuning alone ,is that enouch to use the dance routines, and all that is included poses.or does these also need to adjusted?
