AR Parrot Drone Movement icon AR Parrot Drone Movement Control Parrot AR Drone v1/v2 via ARC: keyboard, joystick, speech, Wii, web; camera feed, face/color/motion/glyph tracking. Try it →
@Nomad... Have you tried charging a battery with either one of the chargers? Check the voltage of your batteries as well before and after using the charger(s)... If it doesn't charge batteries you know you should use contact us... I think you should have posted this in your other "charger" thread since they seem to be identical problems. No need to create a new thread for the same issue....
