Community Question
Ok the term paralleled means all positives are connected together and all negatives connected from batteries of the same voltage. Paralleled batteries of the same voltage adds their Amp Hour capacity at that voltage.
The term series is where batteries are wired positive to the next batteries negative and positive to another negative. This is commonly called a daisy chain. Series two 6v batteries together and you will have 12v at the same Amp Hour rating.
Ok here's the idea- ezb, motor controller and servos need 6v everything else is 12v. I want to be able to charge them from a home base eventually but for right now it would be through the DC charge port already in omnibot back. This way while running everything has seperate power supplies and all charge from one easy source.
This could easily be.applied without the 12v batteries and just have 4 6v batteries that can seperatly power all the components so there is never a over amping situation of a battery causing a brown out. However with cells having a parralelled side there is a simple charging solution that's easier than using complex balance chargers on each.cell. :)
jstarne1
Commented March 2012
Yes I absolutely want to make a charging station! But I don't know.how so I have not done any design work yet. Any ideas? Drawings? Here's my second option , I can keep everything wired at 12v and use step down convertera I have which are fully adjustable to exact voltage. They are rated at 2a continous each but no rating for max. I have three of these. So one for ezb, one for H bridge and one for servos . How's that sound? Wired all 12v I would have 26ah at 12v which is 312 watt hours. This may run my bot 2 to 6 he depending on wattage draw. How's that sound? I will make New thread for charging base I believe.
ww321q
jstarne1
Where do you propose putting a relay though?
ww321q
Oh I just realized you really need separate chargers or just use a DC to DC converter. The different AH and size batteries require separating the batteries to keep from over charging the littler ones or under charging the big ones.
jstarne1
Yea I believe ill use all 12v cells and use the dc to dc converters to step down the voltage. They are rated for 2 amps each continous so that should be enough I guess.
Question
Avatarby jstarne1
Published Thursday, March 1, 2012
