4c454f
Resolved by thetechguru!
Hi there, when i try to do the Robot course for the Roli or any of the other robots i get the error, error at loading of ippSP library, No DLLs were found in the Waterfall Procedure. where can i find these DLLs it is looking for, i have checked the for forums but am uncertain about downloading files from people i dont know and putting them on my computer.
Error at loading of ippSP library
No DLLs were found in the Waterfall procedure
This issue keeps popping up from time to time. Follow this link and the thread will walk you through a solution. You or someone using your computer uninstalled a third party program and the uninstaller took out more Dills then it should have. Probably GoProCineformStudio. It's an easy fix:
www.sevenforums.com/software/296070-no-dll-were-found-waterfall-procedure-finally-solved.html
Just fyi,
Simply installing any Windows GoPro software causes this issue. Uninstalling doesn't fix it because their installer doesn't clean up the outdated dlls they install. I was involved in the beta test of one of their new cameras and the new software, and complained loudly about this issue but they didn't fix it.
Breaks a lot of apps, not just ARC.
Thank you
