Question
Asked January 2 2016
Community Question
Is there any way to look at how the script for camera tracking was written by Dj? I can read the variables, but I want to see the line by line script.
My goal is to write a tracking script to an X,Y coordinate. Someone wanted to do a similar thing using a GPS module about a year ago.
I see there is a camera coordinate X and Y in the variable list. I wanted to see how it was used in his script.
I can read where the robot is now ( X and Y value), and know where I want it to go (X and Y value). I need to borrow or write how to travel from and to.
Ron R
January 3 2016
Hi Dj,
My end goal is to track to two preset coordinates, loaded from a verbal command ("go to the door").
The following is my idea: I read the loaded variables, then compare these coordinates to coordinates of two tracking cameras, looking at a target on my robot. These cameras are located 90 degrees apart in the area (two out side walls). Using Omni wheels mounted on two continuous servos, I plan on moving in the direction to match these coordinates. As the number get closer, I slow the continuous servos until the numbers match, then stop.
I started to write a concept script on paper using only one camera/servo and one continuous servo. I know your camera tracking lists an x and y coordinate and wanted to see how you wrote the script to track to them. This way I could see if I was on the right track. My idea is to do compares, then adjust the position of the robot until it matches.
I am a very new writer of scripts. The only exposure to programming was ladder logic and machine code many many years ago....LOL.. I will continue to play and post the script once it is written.
Any help or direction is appreciated. I really want to try this idea. I have future ideas to incorporate into it once it works.
Ron R
DJ Sures
January 3 2016
You cannot use a continuous rotation servo for tracking because it is unable to respond to position commands. It doesn't have a sense of positioning, it only knows to move a direction.
January 3 2016
No, I am using the continuous servos to move only the robot. The camera is mounted on a regular servo, which is on a stationary location by an outside wall.. It is used to track the robot. For the initial test, I will have a long cable from the EZB in the Adventure Bot to the servo under the camera by a perimeter wall. As the Bot moves, the value sent to the camera servo to follow the target on the robot's back is my feedback. I will be using an Adventure Bot as the Target and a web cam connected to my computer as the feed back. I will load a coordinate and hopefully track to it.
I may have to make a video of the concept to eliminate some of the hardware confusion.
Ron R
DJ Sures
January 3 2016
Apologies Andy, i feel the question regarding how the vision tracking system identifies object positioning within EZ-Builder may be highly above your current programming capabilities based on this thread.
I do encourage learning - which is why we spent years developing and growing the LEARN section of this website. There is an activities course which will be very important to the education process. I recommend successfully completing the activities. Once you have accomplished the activities and have a grasp of logic programming, use the EXAMPLES folder in EZ-Builder to view ez-script examples.
This is because the question that you are asking about how object positioning is identified is quite complicated. There are many "steps" with complicated programming that identifies and detects objects. However, the answer to your specific question about how the detected object's position has been identified uses the aforge blobcounter library - which is as good or better than i could have written - which is why building off existing frameworks is important. Much like how you create robot projects in EZ-Builder...
This is because without EZ-Builder, you would need to understand this. And remember, this is only one module of 30 or so that relates to vision tracking in EZ-Builder. If this doesn't make sense to you, stick with EZ-Builder :). This code example is responsible for identifying the detected object position and assigning to EZ-Builder variables:
Code:
// AForge Image Processing Library
// AForge.NET framework
// http://www.aforgenet.com/framework/
// Copyright © AForge.NET, 2005-2012
// contacts@aforgenet.com
namespace AForge.Imaging
using System;
using System.Collections.Generic;
using System.Drawing;
using System.Drawing.Imaging;
using AForge;
/// <summary>
/// Possible object orders.
/// </summary>
/// <remarks>The enumeration defines possible sorting orders of objects, found by blob
/// counting classes.</remarks>
public enum ObjectsOrder
/// <summary>
/// Unsorted order (as it is collected by algorithm).
/// </summary>
None,
/// <summary>
/// Objects are sorted by size in descending order (bigger objects go first).
/// Size is calculated as <b>Width * Height</b>.
/// </summary>
Size,
/// <summary>
/// Objects are sorted by area in descending order (bigger objects go first).
/// </summary>
Area,
/// <summary>
/// Objects are sorted by Y coordinate, then by X coordinate in ascending order
/// (smaller coordinates go first).
/// </summary>
YX,
/// <summary>
/// Objects are sorted by X coordinate, then by Y coordinate in ascending order
/// </summary>
XY
/// <summary>
/// Base class for different blob counting algorithms.
/// </summary>
/// <remarks><para>The class is abstract and serves as a base for different blob counting algorithms.
/// Classes, which inherit from this base class, require to implement <see cref="BuildObjectsMap"/>
/// method, which does actual building of object's label's map.</para>
/// <para>For blobs' searcing usually all inherited classes accept binary images, which are actually
/// grayscale thresholded images. But the exact supported format should be checked in particular class,
/// inheriting from the base class. For blobs' extraction the class supports grayscale (8 bpp indexed)
/// and color images (24 and 32 bpp).</para>
/// <para>Sample usage:</para>
/// <code>
/// // create an instance of blob counter algorithm
/// BlobCounterBase bc = new ...
/// // set filtering options
/// bc.FilterBlobs = true;
/// bc.MinWidth = 5;
/// bc.MinHeight = 5;
/// // process binary image
/// bc.ProcessImage( image );
/// Blob[] blobs = bc.GetObjects( image, false );
/// // process blobs
/// foreach ( Blob blob in blobs )
/// // blob.Rectangle - blob's rectangle
/// // blob.Image - blob's image
/// </code>
/// </remarks>
public abstract class BlobCounterBase
// found blobs
List<Blob> blobs = new List<Blob>( );
// objects' sort order
private ObjectsOrder objectsOrder = ObjectsOrder.None;
// filtering by size is required or not
private bool filterBlobs = false;
private IBlobsFilter filter = null;
// coupled size filtering or not
private bool coupledSizeFiltering = false;
// blobs' minimal and maximal size
private int minWidth = 1;
private int minHeight = 1;
private int maxWidth = int.MaxValue;
private int maxHeight = int.MaxValue;
/// <summary>
/// Objects count.
/// </summary>
protected int objectsCount;
/// <summary>
/// Objects' labels.
/// </summary>
protected int[] objectLabels;
/// <summary>
/// Width of processed image.
/// </summary>
protected int imageWidth;
/// <summary>
/// Height of processed image.
/// </summary>
protected int imageHeight;
/// <summary>
/// Objects count.
/// </summary>
/// <remarks><para>Number of objects (blobs) found by <see cref="ProcessImage(Bitmap)"/> method.
/// </para></remarks>
public int ObjectsCount
get { return objectsCount; }
/// <summary>
/// </summary>
/// <remarks>The array of <b>width</b> * <b>height</b> size, which holds
/// labels for all objects. Background is represented with <b>0</b> value,
/// but objects are represented with labels starting from <b>1</b>.</remarks>
public int[] ObjectLabels
get { return objectLabels; }
/// <summary>
/// Objects sort order.
/// </summary>
/// <remarks><para>The property specifies objects' sort order, which are provided
/// by <see cref="GetObjectsRectangles"/>, <see cref="GetObjectsInformation"/>, etc.
public ObjectsOrder ObjectsOrder
get { return objectsOrder; }
set { objectsOrder = value; }
/// <summary>
/// Specifies if blobs should be filtered.
/// </summary>
/// <remarks><para>If the property is equal to <b>false</b>, then there is no any additional
/// post processing after image was processed. If the property is set to <b>true</b>, then
/// blobs filtering is done right after image processing routine. If <see cref="BlobsFilter"/>
/// is set, then custom blobs' filtering is done, which is implemented by user. Otherwise
/// blobs are filtered according to dimensions specified in <see cref="MinWidth"/>,
/// <see cref="MinHeight"/>, <see cref="MaxWidth"/> and <see cref="MaxHeight"/> properties.</para>
/// <para>Default value is set to <see langword="false"/>.</para></remarks>
public bool FilterBlobs
get { return filterBlobs; }
set { filterBlobs = value; }
/// <summary>
/// Specifies if size filetering should be coupled or not.
/// </summary>
/// <remarks><para>In uncoupled filtering mode, objects are filtered out in the case if
/// their width is smaller than <see cref="MinWidth"/> <b>or</b> height is smaller than
/// <see cref="MinHeight"/>. But in coupled filtering mode, objects are filtered out in
/// the case if their width is smaller than <see cref="MinWidth"/> <b>and</b> height is
/// smaller than <see cref="MinHeight"/>. In both modes the idea with filtering by objects'
/// maximum size is the same as filtering by objects' minimum size.</para>
/// <para>Default value is set to <see langword="false"/>, what means uncoupled filtering by size.</para>
/// </remarks>
public bool CoupledSizeFiltering
get { return coupledSizeFiltering; }
set { coupledSizeFiltering = value; }
/// <summary>
/// Minimum allowed width of blob.
/// </summary>
/// <remarks><para>The property specifies minimum object's width acceptable by blob counting
/// routine and has power only when <see cref="FilterBlobs"/> property is set to
/// <see langword="true"/> and <see cref="BlobsFilter">custom blobs' filter</see> is
/// set to <see langword="null"/>.</para>
/// <para>See documentation to <see cref="CoupledSizeFiltering"/> for additional information.</para>
/// </remarks>
public int MinWidth
get { return minWidth; }
set { minWidth = value; }
/// <summary>
/// Minimum allowed height of blob.
/// </summary>
/// <remarks><para>The property specifies minimum object's height acceptable by blob counting
/// </remarks>
public int MinHeight
get { return minHeight; }
set { minHeight = value; }
/// <summary>
/// Maximum allowed width of blob.
/// </summary>
/// <remarks><para>The property specifies maximum object's width acceptable by blob counting
/// </remarks>
public int MaxWidth
get { return maxWidth; }
set { maxWidth = value; }
/// <summary>
/// Maximum allowed height of blob.
/// </summary>
/// <remarks><para>The property specifies maximum object's height acceptable by blob counting
/// </remarks>
public int MaxHeight
get { return maxHeight; }
set { maxHeight = value; }
/// <summary>
/// Custom blobs' filter to use.
/// </summary>
/// <remarks><para>The property specifies custom blobs' filtering routine to use. It has
/// effect only in the case if <see cref="FilterBlobs"/> property is set to <see langword="true"/>.</para>
/// <para><note>When custom blobs' filtering routine is set, it has priority over default filtering done
/// with <see cref="MinWidth"/>, <see cref="MinHeight"/>, <see cref="MaxWidth"/> and <see cref="MaxHeight"/>.</note></para>
/// </remarks>
public IBlobsFilter BlobsFilter
get { return filter; }
set { filter = value; }
/// <summary>
/// Initializes a new instance of the <see cref="BlobCounterBase"/> class.
/// </summary>
/// <remarks>Creates new instance of the <see cref="BlobCounterBase"/> class with
/// an empty objects map. Before using methods, which provide information about blobs
/// or extract them, the <see cref="ProcessImage(Bitmap)"/>,
/// <see cref="ProcessImage(BitmapData)"/> or <see cref="ProcessImage(UnmanagedImage)"/>
/// method should be called to collect objects map.</remarks>
public BlobCounterBase( ) { }
/// <summary>
/// </summary>
/// <param name="image">Binary image to look for objects in.</param>
/// initialized objects map built by calling <see cref="ProcessImage(Bitmap)"/> method.</remarks>
public BlobCounterBase( Bitmap image )
/// <summary>
/// </summary>
/// <param name="imageData">Binary image data to look for objects in.</param>
/// initialized objects map built by calling <see cref="ProcessImage(BitmapData)"/> method.</remarks>
public BlobCounterBase( BitmapData imageData )
ProcessImage( imageData );
/// <summary>
/// </summary>
/// <param name="image">Unmanaged binary image to look for objects in.</param>
/// initialized objects map built by calling <see cref="ProcessImage(UnmanagedImage)"/> method.</remarks>
public BlobCounterBase( UnmanagedImage image )
/// <summary>
/// Build objects map.
/// </summary>
/// <param name="image">Source binary image.</param>
/// <remarks><para>Processes the image and builds objects map, which is used later to extracts blobs.</para></remarks>
/// <exception cref="UnsupportedImageFormatException">Unsupported pixel format of the source image.</exception>
public void ProcessImage( Bitmap image )
// lock source bitmap data
BitmapData imageData = image.LockBits(
new Rectangle( 0, 0, image.Width, image.Height ),
ImageLockMode.ReadOnly, image.PixelFormat );
try
// process image
finally
// unlock source image
image.UnlockBits( imageData );
/// <summary>
/// </summary>
/// <param name="imageData">Source binary image data.</param>
public void ProcessImage( BitmapData imageData )
// do actual objects map building
ProcessImage( new UnmanagedImage( imageData ) );
/// <summary>
/// Build object map from raw image data.
/// </summary>
/// <param name="image">Source unmanaged binary image data.</param>
/// <exception cref="InvalidImagePropertiesException">Thrown by some inherited classes if some image property other
/// than the pixel format is not supported. See that class's documentation or the exception message for details.</exception>
public void ProcessImage( UnmanagedImage image )
imageWidth = image.Width;
imageHeight = image.Height;
BuildObjectsMap( image );
// collect information about blobs
CollectObjectsInfo( image );
// filter blobs by size if required
if ( filterBlobs )
// labels remapping array
int[] labelsMap = new int[objectsCount + 1];
for ( int i = 1; i <= objectsCount; i++ )
labelsMap = i;
// check dimension of all objects and filter them
int objectsToRemove = 0;
if ( filter == null )
for ( int i = objectsCount - 1; i >= 0; i-- )
int blobWidth = blobs.Rectangle.Width;
int blobHeight = blobs.Rectangle.Height;
if ( coupledSizeFiltering == false )
// uncoupled filtering
if (
( blobWidth < minWidth ) || ( blobHeight < minHeight ) ||
( blobWidth > maxWidth ) || ( blobHeight > maxHeight ) )
labelsMap[i + 1] = 0;
objectsToRemove++;
blobs.RemoveAt( i );
else
// coupled filtering
if (
( ( blobWidth < minWidth ) && ( blobHeight < minHeight ) ) ||
( ( blobWidth > maxWidth ) && ( blobHeight > maxHeight ) ) )
objectsToRemove++;
else
if ( !filter.Check( blobs ) )
objectsToRemove++;
// update labels remapping array
int label = 0;
if ( labelsMap != 0 )
label++;
// update remapping array
labelsMap = label;
// repair object labels
for ( int i = 0, n = objectLabels.Length; i < n; i++ )
objectLabels = labelsMap[objectLabels];
objectsCount -= objectsToRemove;
// repair IDs
for ( int i = 0, n = blobs.Count; i < n; i++ )
blobs.ID = i + 1;
// do we need to sort the list?
if ( objectsOrder != ObjectsOrder.None )
blobs.Sort( new BlobsSorter( objectsOrder ) );
/// <summary>
/// Get objects' rectangles.
/// </summary>
/// <returns>Returns array of objects' rectangles.</returns>
/// <remarks>The method returns array of objects rectangles. Before calling the
/// method, the <see cref="ProcessImage(Bitmap)"/>, <see cref="ProcessImage(BitmapData)"/>
/// or <see cref="ProcessImage(UnmanagedImage)"/> method should be called, which will
/// build objects map.</remarks>
/// <exception cref="ApplicationException">No image was processed before, so objects' rectangles
/// can not be collected.</exception>
public Rectangle[] GetObjectsRectangles( )
// check if objects map was collected
if ( objectLabels == null )
throw new ApplicationException( "Image should be processed before to collect objects map." );
Rectangle[] rects = new Rectangle[objectsCount];
for ( int i = 0; i < objectsCount; i++ )
rects = blobs.Rectangle;
return rects;
/// <summary>
/// Get objects' information.
/// </summary>
/// <returns>Returns array of partially initialized blobs (without <see cref="Blob.Image"/> property initialized).</returns>
/// <remarks><para>By the amount of provided information, the method is between <see cref="GetObjectsRectangles"/> and
/// <see cref="GetObjects( UnmanagedImage, bool )"/> methods. The method provides array of blobs without initialized their image.
/// Blob's image may be extracted later using <see cref="ExtractBlobsImage( Bitmap, Blob, bool )"/>
/// or <see cref="ExtractBlobsImage( UnmanagedImage, Blob, bool )"/> method.
/// <example>
/// <code>
/// // create blob counter and process image
/// BlobCounter bc = new BlobCounter( sourceImage );
/// // specify sort order
/// bc.ObjectsOrder = ObjectsOrder.Size;
/// // get objects' information (blobs without image)
/// Blob[] blobs = bc.GetObjectInformation( );
/// // check blob's properties
/// if ( blob.Rectangle.Width > 50 )
/// // the blob looks interesting, let's extract it
/// bc.ExtractBlobsImage( sourceImage, blob );
/// </code>
/// </example>
/// <exception cref="ApplicationException">No image was processed before, so objects' information
public Blob[] GetObjectsInformation( )
Blob[] blobsToReturn = new Blob[objectsCount];
// create each blob
for ( int k = 0; k < objectsCount; k++ )
blobsToReturn[k] = new Blob( blobs[k] );
return blobsToReturn;
/// <summary>
/// Get blobs.
/// </summary>
/// <param name="image">Source image to extract objects from.</param>
/// <returns>Returns array of blobs.</returns>
/// <param name="extractInOriginalSize">Specifies size of blobs' image to extract.
/// If set to <see langword="true"/> each blobs' image will have the same size as
/// the specified image. If set to <see langword="false"/> each blobs' image will
/// have the size of its blob.</param>
/// <remarks><para>The method returns array of blobs. Before calling the
/// or <see cref="ProcessImage(UnmanagedImage)"/> method should be called, which will build
/// objects map.</para>
/// <para>The method supports 24/32 bpp color and 8 bpp indexed grayscale images.</para>
/// </remarks>
/// <exception cref="UnsupportedImageFormatException">Unsupported pixel format of the provided image.</exception>
public Blob[] GetObjects( Bitmap image, bool extractInOriginalSize )
Blob[] blobs = null;
try
// process image
blobs = GetObjects( new UnmanagedImage( imageData ), extractInOriginalSize );
finally
// unlock source images
return blobs;
/// <summary>
/// Get blobs.
/// </summary>
/// <param name="image">Source unmanaged image to extract objects from.</param>
/// </remarks>
public Blob[] GetObjects( UnmanagedImage image, bool extractInOriginalSize )
if (
( image.PixelFormat != PixelFormat.Format24bppRgb ) &&
( image.PixelFormat != PixelFormat.Format8bppIndexed ) &&
( image.PixelFormat != PixelFormat.Format32bppRgb ) &&
( image.PixelFormat != PixelFormat.Format32bppArgb ) &&
( image.PixelFormat != PixelFormat.Format32bppPArgb )
throw new UnsupportedImageFormatException( "Unsupported pixel format of the provided image." );
// image size
int width = image.Width;
int height = image.Height;
int srcStride = image.Stride;
int pixelSize = Bitmap.GetPixelFormatSize( image.PixelFormat ) / 8;
Blob[] objects = new Blob[objectsCount];
// create each image
int objectWidth = blobs[k].Rectangle.Width;
int objectHeight = blobs[k].Rectangle.Height;
int blobImageWidth = ( extractInOriginalSize ) ? width : objectWidth;
int blobImageHeight = ( extractInOriginalSize ) ? height : objectHeight;
int xmin = blobs[k].Rectangle.X;
int xmax = xmin + objectWidth - 1;
int ymin = blobs[k].Rectangle.Y;
int ymax = ymin + objectHeight - 1;
int label = blobs[k].ID;
// create new image
UnmanagedImage dstImage = UnmanagedImage.Create( blobImageWidth, blobImageHeight, image.PixelFormat );
// copy image
unsafe
byte* src = (byte*) image.ImageData.ToPointer( ) + ymin * srcStride + xmin * pixelSize;
byte* dst = (byte*) dstImage.ImageData.ToPointer( );
int p = ymin * width + xmin;
if ( extractInOriginalSize )
// allign destination pointer also
dst += ymin * dstImage.Stride + xmin * pixelSize;
int srcOffset = srcStride - objectWidth * pixelSize;
int dstOffset = dstImage.Stride - objectWidth * pixelSize;
int labelsOffset = width - objectWidth;
// for each line
for ( int y = ymin; y <= ymax; y++ )
// copy each pixel
for ( int x = xmin; x <= xmax; x++, p++, dst += pixelSize, src += pixelSize )
if ( objectLabels[p] == label )
// copy pixel
*dst = *src;
if ( pixelSize > 1 )
dst[1] = src[1];
dst[2] = src[2];
if ( pixelSize > 3 )
dst[3] = src[3];
src += srcOffset;
dst += dstOffset;
p += labelsOffset;
objects[k] = new Blob( blobs[k] );
objects[k].Image = dstImage;
objects[k].OriginalSize = extractInOriginalSize;
return objects;
/// <summary>
/// Extract blob's image.
/// </summary>
/// <param name="image">Source image to extract blob's image from.</param>
/// <param name="blob">Blob which is required to be extracted.</param>
/// <remarks><para>The method is used to extract image of partially initialized blob, which
/// was provided by <see cref="GetObjectsInformation"/> method. Before calling the
/// </remarks>
/// <exception cref="ApplicationException">No image was processed before, so blob
/// can not be extracted.</exception>
public void ExtractBlobsImage( Bitmap image, Blob blob, bool extractInOriginalSize )
try
// process image
ExtractBlobsImage( new UnmanagedImage( imageData ), blob, extractInOriginalSize );
finally
/// <summary>
/// </summary>
/// <param name="image">Source unmanaged image to extract blob's image from.</param>
/// </remarks>
public void ExtractBlobsImage( UnmanagedImage image, Blob blob, bool extractInOriginalSize )
if (
// image size
int objectWidth = blob.Rectangle.Width;
int objectHeight = blob.Rectangle.Height;
int xmin = blob.Rectangle.Left;
int ymin = blob.Rectangle.Top;
int label = blob.ID;
// create new image
blob.Image = UnmanagedImage.Create( blobImageWidth, blobImageHeight, image.PixelFormat );
blob.OriginalSize = extractInOriginalSize;
// copy image
unsafe
byte* dst = (byte*) blob.Image.ImageData.ToPointer( );
dst += ymin * blob.Image.Stride + xmin * pixelSize;
int dstOffset = blob.Image.Stride - objectWidth * pixelSize;
// for each line
// copy each pixel
// copy pixel
*dst = *src;
dst[1] = src[1];
dst[2] = src[2];
dst[3] = src[3];
src += srcOffset;
dst += dstOffset;
p += labelsOffset;
/// <summary>
/// Get list of points on the left and right edges of the blob.
/// </summary>
/// <param name="blob">Blob to collect edge points for.</param>
/// <param name="leftEdge">List of points on the left edge of the blob.</param>
/// <param name="rightEdge">List of points on the right edge of the blob.</param>
/// <remarks><para>The method scans each line of the blob and finds the most left and the
/// most right points for it adding them to appropriate lists. The method may be very
/// useful in conjunction with different routines from <see cref="AForge.Math.Geometry"/>,
/// which allow finding convex hull or quadrilateral's corners.</para>
/// <para><note>Both lists of points are sorted by Y coordinate - points with smaller Y
/// value go first.</note></para>
/// </remarks>
public void GetBlobsLeftAndRightEdges( Blob blob, out List<IntPoint> leftEdge, out List<IntPoint> rightEdge )
leftEdge = new List<IntPoint>( );
rightEdge = new List<IntPoint>( );
int xmax = xmin + blob.Rectangle.Width - 1;
int ymax = ymin + blob.Rectangle.Height - 1;
// for each line
// scan from left to right
int p = y * imageWidth + xmin;
for ( int x = xmin; x <= xmax; x++, p++ )
leftEdge.Add( new IntPoint( x, y ) );
break;
// scan from right to left
p = y * imageWidth + xmax;
for ( int x = xmax; x >= xmin; x--, p-- )
rightEdge.Add( new IntPoint( x, y ) );
break;
/// <summary>
/// Get list of points on the top and bottom edges of the blob.
/// </summary>
/// <param name="topEdge">List of points on the top edge of the blob.</param>
/// <param name="bottomEdge">List of points on the bottom edge of the blob.</param>
/// <remarks><para>The method scans each column of the blob and finds the most top and the
/// most bottom points for it adding them to appropriate lists. The method may be very
/// <para><note>Both lists of points are sorted by X coordinate - points with smaller X
/// </remarks>
public void GetBlobsTopAndBottomEdges( Blob blob, out List<IntPoint> topEdge, out List<IntPoint> bottomEdge )
topEdge = new List<IntPoint>( );
bottomEdge = new List<IntPoint>( );
// for each column
for ( int x = xmin; x <= xmax; x++ )
// scan from top to bottom
int p = ymin * imageWidth + x;
for ( int y = ymin; y <= ymax; y++, p += imageWidth )
topEdge.Add( new IntPoint( x, y ) );
break;
// scan from bottom to top
p = ymax * imageWidth + x;
for ( int y = ymax; y >= ymin; y--, p -= imageWidth )
bottomEdge.Add( new IntPoint( x, y ) );
break;
/// <summary>
/// Get list of object's edge points.
/// </summary>
/// <returns>Returns unsorted list of blob's edge points.</returns>
/// <remarks><para>The method scans each row and column of the blob and finds the
/// most top/bottom/left/right points. The method returns similar result as if results of
/// both <see cref="GetBlobsLeftAndRightEdges"/> and <see cref="GetBlobsTopAndBottomEdges"/>
/// methods were combined, but each edge point occurs only once in the list.</para>
/// <para><note>Edge points in the returned list are not ordered. This makes the list unusable
/// for visualization with methods, which draw polygon or poly-line. But the returned list
/// can be used with such algorithms, like convex hull search, shape analyzer, etc.</note></para>
/// </remarks>
public List<IntPoint> GetBlobsEdgePoints( Blob blob )
List<IntPoint> edgePoints = new List<IntPoint>( );
// array of already processed points on left/right edges
// (index in these arrays represent Y coordinate, but value - X coordinate)
int[] leftProcessedPoints = new int[blob.Rectangle.Height];
int[] rightProcessedPoints = new int[blob.Rectangle.Height];
// for each line
edgePoints.Add( new IntPoint( x, y ) );
leftProcessedPoints[y - ymin] = x;
break;
// avoid adding the point we already have
if ( leftProcessedPoints[y - ymin] != x )
rightProcessedPoints[y - ymin] = x;
break;
// for each column
for ( int y = ymin, y0 = 0; y <= ymax; y++, y0++, p += imageWidth )
if ( ( leftProcessedPoints[y0] != x ) &&
( rightProcessedPoints[y0] != x ) )
break;
for ( int y = ymax, y0 = ymax - ymin; y >= ymin; y--, y0--, p -= imageWidth )
break;
return edgePoints;
/// <summary>
/// Actual objects map building.
/// </summary>
/// <param name="image">Unmanaged image to process.</param>
/// <remarks><note>By the time this method is called bitmap's pixel format is not
/// yet checked, so this should be done by the class inheriting from the base class.
/// <see cref="imageWidth"/> and <see cref="imageHeight"/> members are initialized
/// before the method is called, so these members may be used safely.</note></remarks>
protected abstract void BuildObjectsMap( UnmanagedImage image );
#region Private Methods - Collecting objects' rectangles
// Collect objects' rectangles
private unsafe void CollectObjectsInfo( UnmanagedImage image )
int i = 0, label;
// create object coordinates arrays
int[] x1 = new int[objectsCount + 1];
int[] y1 = new int[objectsCount + 1];
int[] x2 = new int[objectsCount + 1];
int[] y2 = new int[objectsCount + 1];
int[] area = new int[objectsCount + 1];
long[] xc = new long[objectsCount + 1];
long[] yc = new long[objectsCount + 1];
long[] meanR = new long[objectsCount + 1];
long[] meanG = new long[objectsCount + 1];
long[] meanB = new long[objectsCount + 1];
long[] stdDevR = new long[objectsCount + 1];
long[] stdDevG = new long[objectsCount + 1];
long[] stdDevB = new long[objectsCount + 1];
for ( int j = 1; j <= objectsCount; j++ )
x1[j] = imageWidth;
y1[j] = imageHeight;
byte* src = (byte*) image.ImageData.ToPointer( );
if ( image.PixelFormat == PixelFormat.Format8bppIndexed )
int offset = image.Stride - imageWidth;
byte g; // pixel's grey value
// walk through labels array
for ( int y = 0; y < imageHeight; y++ )
for ( int x = 0; x < imageWidth; x++, i++, src++ )
// get current label
label = objectLabels;
// skip unlabeled pixels
if ( label == 0 )
continue;
// check and update all coordinates
if ( x < x1[label] )
x1[label] = x;
if ( x > x2[label] )
x2[label] = x;
if ( y < y1[label] )
y1[label] = y;
if ( y > y2[label] )
y2[label] = y;
area[label]++;
xc[label] += x;
yc[label] += y;
g = *src;
meanG[label] += g;
stdDevG[label] += g * g;
src += offset;
meanR[j] = meanB[j] = meanG[j];
stdDevR[j] = stdDevB[j] = stdDevG[j];
else
// color images
int offset = image.Stride - imageWidth * pixelSize;
byte r, g, b; // RGB value
for ( int x = 0; x < imageWidth; x++, i++, src += pixelSize )
if ( label == 0 )
continue;
x1[label] = x;
x2[label] = x;
y1[label] = y;
y2[label] = y;
area[label]++;
xc[label] += x;
yc[label] += y;
r = src[RGB.R];
g = src[RGB.G];
b = src[RGB.B];
meanR[label] += r;
meanG[label] += g;
meanB[label] += b;
stdDevR[label] += r * r;
stdDevB[label] += b * b;
src += offset;
// create blobs
blobs.Clear( );
int blobArea = area[j];
Blob blob = new Blob( j, new Rectangle( x1[j], y1[j], x2[j] - x1[j] + 1, y2[j] - y1[j] + 1 ) );
blob.Area = blobArea;
blob.Fullness = (double) blobArea / ( ( x2[j] - x1[j] + 1 ) * ( y2[j] - y1[j] + 1 ) );
blob.CenterOfGravity = new AForge.Point( (float) xc[j] / blobArea, (float) yc[j] / blobArea );
blob.ColorMean = Color.FromArgb( (byte) ( meanR[j] / blobArea ), (byte) ( meanG[j] / blobArea ), (byte) ( meanB[j] / blobArea ) );
blob.ColorStdDev = Color.FromArgb(
(byte) ( Math.Sqrt( stdDevR[j] / blobArea - blob.ColorMean.R * blob.ColorMean.R ) ),
(byte) ( Math.Sqrt( stdDevG[j] / blobArea - blob.ColorMean.G * blob.ColorMean.G ) ),
(byte) ( Math.Sqrt( stdDevB[j] / blobArea - blob.ColorMean.B * blob.ColorMean.B ) ) );
blobs.Add( blob );
// Rectangles' and blobs' sorter
private class BlobsSorter : System.Collections.Generic.IComparer<Blob>
private ObjectsOrder order;
public BlobsSorter( ObjectsOrder order )
this.order = order;
public int Compare( Blob a, Blob b )
Rectangle aRect = a.Rectangle;
Rectangle bRect = b.Rectangle;
switch ( order )
case ObjectsOrder.Size: // sort by size
// the order is changed to descending
return ( bRect.Width * bRect.Height - aRect.Width * aRect.Height );
case ObjectsOrder.Area: // sort by area
return b.Area - a.Area;
case ObjectsOrder.YX: // YX order
return ( ( aRect.Y * 100000 + aRect.X ) - ( bRect.Y * 100000 + bRect.X ) );
case ObjectsOrder.XY: // XY order
return ( ( aRect.X * 100000 + aRect.Y ) - ( bRect.X * 100000 + bRect.Y ) );
return 0;
#endregion
January 3 2016
Thanks Dj,
I had assumed the "camera tracking" used a "script" developed thru EZ Builder, and additional code running in the background. I just looked at the surface results and never put thought into what was really going on.
Thanks for posting the information, but as you can tell, my background does not give me the ability to use it.
I have re-posted my thread on tracking using servo position information, and will continue to go forward with that scripting.
Thanks again,
Ron R
