Community Question
Hello everyone, first of all I want to thank everyone in the community for providing essential information regarding the EZ-Robot. The video below is one of the successful testing of Autonomous Navigation Robot, using the Roli Rover Platform integrating both Ez-Builder Software and Roborealm. This was my Final Year Project and I have just finished demo-ing the project last week. Maybe after the report writing, I will release a tutorial of how I did it? Just to give back to the community. Of course, I am open to suggestions and ideas. But thank you all again.
Regards,
Recon
Recon
Commented May 2017
@PhG Thanks very much, appreciate it.
@Richard R I did actually seen that video, and it gave me the confidence that it is in fact do-able. Thank you for your contributions. ;) ;)
faengelm
Commented May 2017
@Richard-R
I
found your post.... :)
https://www.ez-robot.com/Community/Forum/posts.aspx?threadId=8381
@Recon,
Thanks for your offer of help. I will did up my notes on my issues
Regards,
Frank
faengelm
Commented May 2017
@Recon
Thanks
I now have the Marker Mode making a pretty accurate map, but am having problems getting the EZB robot to follow the map in the Navigation Mode.
Which EZBRobot variables are you using in your EZB scripts for motor control?
I have been trying $RR_NV_L_MOTOR and $RR_NV_R_MOTOR without success
Can you share you scripts for the movement panel?
Regards,
Frank
Recon
Commented May 2017
@faengelm
Hi
there, basically you have to set up the H-Bridge PWM movement panel and write a script for the movement of the robot, called it a AVM Navigator. You wouldn't be needing the $RR_NV_L_MOTOR and $RR_NV_R_MOTOR variables. So it would be something like this,
:loopForever
if($RR_NV_FORWARD) //reading forward button
SetSpeed (96,96) //set speed
Forward() //Forward Movement
elseif ($RV_NV_LEFT)
SetSpeed(96)
Left()
and so on for other movements..
Basically with the script above you should be able to manually control your robot in Marker Mode and in Navigation by map it will virtually pressed the key for autonomous navigation. Of course, TCP connections have to be enabled to sent the movement signals as well. Hope that helps you.
Cheers.
Recon ;) ;)
faengelm
Commented May 2017
@recon,
Thanks
for the quick reply... I'll try this
Frank
Question
AvatarRecon
Asked on Sunday, April 30, 2017
