France
Good Evening, I Don'T Know I
Good evening, I don't know if it's possible,
I use a SARAH framework with plugins with a Dictionnary plugin that parse my answer. It works perfectly and I get my answer. I created a script that I named dico that I would like to launch with an HTTP request and a ControlCommand.
$VoiceStart = "<prosody pitch='+10%' rate='-5%' range='+5%' contour='(0%,+30Hz) (10%,-2st) (40%,+10Hz)'> "
$VoiceEnd = "</prosody>"
$search = "voiture"
$SynbotTextResponse = HTTPget("http://127.0.0.1:8080/SARAH/dictionary?text="+$search)
SayWait($VoiceStart +$SynbotTextResponse+ $VoiceEnd)
But here is my question:
You will understand, instead of voiture I would like to put the object of my research $search = "voiture"
http://192.168.1.78/exec?password=admin&script=ControlCommand("dico".........search("mysearch")
Is it possible?
Another thing and it's important, I always have a problem with the accents in my answers. Is an update planned?
[url=https://synthiam.com/Question/3771][size=2][font=Verdana, Arial, Helvetica, sans-serif]see here[/font][/size]
Thanks
I found and it was easy as pie. I forgot to mention I use Synbot.
<Model>
<Pattern>
<Item>DICO *</Item>
</Pattern>
<Response>
<x:EZcmd>HTTPget("http://127.0.0.1:8080/SARAH/dictionary?text=<Match />")</x:EZcmd>
</Response>
</Model>
Now I will be able to parse all my sites that I wish (dico, wikipedia, weather ...) with my framework.
But I have always problem with the accents, it's impossible to use this (for the time being?).
#2   — Edited
I had already discussed the problem here
Here I have my accents in my answer. User-inserted image mécanisme automatique capable d'exécuter certaines tâches selon un programme fixe ou modifiable
But in synbot the accents are not present and the answer is unusable. User-inserted image mcanisme automatique capable d'excuter certaines tches selon un programme fixe ou modifiable
@DJ [/b]I specify that the site dictionary.reverso.net is in UTF-8,  my plugin gives the answer in UTF-8 with all the accents.
request({ 'uri' : url ,'htm':{'Accept-Charset': 'UTF-8'}, }, function (err, response, body){
I did the tests on 2 PCs and others ARC skill plugins (pandorabot, synbot,...)
@Dj Well, I found a solution by doing a regex. It's not really beautiful but it works, that's all that matters.
match = match.replace(/[éèê]/g,"&#233;");
