NAudio.MmException: NoDriver calling waveInStop
at NAudio.Wave.WaveInEvent.StopRecording()
at ARC.UCForms.FormBingSpeechRecognition.OcNPJAqI73b(Object , FormClosingEventArgs )
at System.Windows.Forms.Form.OnFormClosing(FormClosingEventArgs e)
at System.Windows.Forms.Form.WmClose(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Try uninstalling the old ARC installation using the Windows install program. Make sure you have a copy of your projects. Turn off and then turn on your computer. Then redownload the latest version of ARC and reinstall.
Your first explanation of your problem said you had problems saving your project. In your lase post you mention opening a new project. Where do you actually see the problem? Is it with both actions?
I downloaded the latest ARC version. I opened my old project that has Bing Speech in it. and then clicked New. Everything worked as it should. Then I opened a new project and installed a new Bing Speech app then opened a new project. Everything worked as it should. I also saved the new project to both my computer and the cloud with no issues. I used both the Save and Save As methods with no issues.
The problem must be your installation of ARC or something on your computer keeping it from saving.
Does everything else work for yo with ARC other then saving or opening a new project?
You're right @EZAng something is up with Bing Speech recognition. If @DJ Sures doesn't see this I'll send him a message by the end of the day.
Ok thanks
When I shut ARC it says:
Version: 2020.09.08.00
NAudio.MmException: NoDriver calling waveInStop at NAudio.Wave.WaveInEvent.StopRecording() at ARC.UCForms.FormBingSpeechRecognition.OcNPJAqI73b(Object , FormClosingEventArgs ) at System.Windows.Forms.Form.OnFormClosing(FormClosingEventArgs e) at System.Windows.Forms.Form.WmClose(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
EzAng
Oh boy. I have a feeling we're not in Kansas anymore Toto.
Lol, looks like it's working again! @DJ took care of it :D
Yes, it works for a while, thanks Jeremie, and thanks DJ
Now it just freezes when click save, or new , it freezes
EzAng
Since I down loaded the 3 updates, my ARC program, after open a program, it says, "not responding", then freezes
when I click save, then new it freezes
EzAng
I deleted Arc, then downloaded it again - same thing happens
it just freezes when I click save, or new
EzAng
Firewall and antivirus turned off for testing? Sounds like something on your computer is stopping this process.
Also, are you saving to cloud or your computer? Do you have the same problem when you save to each?
If to your computer try to change the save path to a folder you know you can find and access. Your path may be bad.
Firewall and antivirus turned is off - I re-booted
This all started when I downloaded the 3 new updates
Start a project with the Bing Speech recognition, the click new - let me know what happens, thanks
I will delete my program and re-do it
I did it and it works some times
EzAng
All my programs work, except the ones with Bing Speech
solved my me today- lol
EzAng
Please delete this old post
Please do not ask for posts to be deleted. It’s not easy to do
